On cloud core 1009 i can set reformat-hold-button-max 78s
go into settings and apply protected routerboard checkbox and no error.
But on smaller devices, map lite or metal or RB962UiGS-5HacT2HnT i can not, it says that current routerboard does not allow for hold button max.
(all is updateted and most recent firmware and routeros and routerboard, 6.41)
Why?
I also want to protect cheaper devices, not only the expensive ones.
i read it, and when i set reformat hold button max, after pressing apply or set protected to enabled,
it says that hold button max is not supported.
why?
Because you did not read it well enough. Especially the first bullet.
The backup RouterBOOT version can not be older than v3.24 version. A special package is provided to upgrade the backup RouterBOOT (DANGEROUS). Newer devices will have this new backup loader already installed at the factory. Download the package for:
MIPSBE platform here SMIPS platform here MMIPS platform here TILE platform here.
I still dont understand, i have version 6.41.4 so it is newest.
Also protected router board enables, it is enabled, only max hold is not supported.
what should i do exactly?
i even tried to install this package, installed, ok, but still - protected routerboard function as it should, but hold max button is not supported.
the device has to have the new bootloader in it’s hardware built in. the button causes the system to load the factory bootloader. this is why I said in the other thread, you must wait until the devices are manufactured with the new bootloader
YOU MUST UPGRADE FACTORY BIOS (factory-firmware) version to use protected RouterBOOT functions!!!
You know the differencies between Software (RouterOS) and BIOS (Firmware / RouterBOOT)?
You have 3.22 factory firmware and must be updated to correctly use protected RouterBOOT (RouterBOOT is not RouterOS)
Follow my guide, is not perfect because I do not know english, but if you READ ALL is useful:
model RB951G-2HnD, mipsbe, firmware-type ar9344, the factory RouterBOOT is upgradable to 3.41? YES
model: CCR1009-8G-1S-1S+, tile, firmware-type: tilegx, the factory RouterBOOT is upgradable to 3.41? YES
everything works fine, after pressing reset button shorter than hold time, it does not do anything.
But i want also that MAX HOLD button to work as wiki says, and this red error says that it does not apply here.
Again:
PROTECTED ROUTERBOARD: WORKS
reformat-hold-button: WORKS
reformat-hold-button-max - does NOT works.
and it should be CHANGED TO:
To use all protected routerboard features you have to have RouterBOOT =>3.38.3 as FACTORY FIRMWARE.
To use it you have to be running on RouterOS 6.40.7 and firmware 3.41.
1.Install routeros 6.40.7
2.Go to System Routerboard upgrade firmware to have 3.41
3.Reboot
4.Download above DPK package
5.Drop this dpk package to winbox
6.Reboot.
7.Now you have Factory firmware 3.41 and you can upgrade your routeros to newest version from System->Packages.
All functionality of protected routerboard is now enabled.
