In Winbox, you can “refresh” an interface. I would like to write a script to automate this. What is the command for it? Is “refresh” same as disabling and then enabling the interface? I appreciate your help. Thank you.
whre do you see this Refresh?
Edgars
In Winbox, click on “Interfaces”. This will cause the “Interface list” to be displayed. The third button on the top row is Refresh. The first two are “Add” and “Remove” I believe. Thanks for responding.
aah you mean in v2.8, that is only for status refreshing, no enable/diisable is made. Such script is useless you are willing to write.
Edgars
