Hi community,
reading a post that mention the possibility for RouterOS 3.0 to refuse connections from clients with low signal strenght, that make troubles to all other clients, i setup the routerOS 3.0 beta4 to an RB 532.
I find on the “connect list” rule (on 3.0) the possibility to accept connections from -xx to -xx … but also in 2.9.38 i find the same rule… not “from-to” but only “from -xx”.
In both cases for my scenario don’t work.
I’m missing something ?? I’m using a PPPoE server on the Access Point RB, with a IP-Pool and external radius auth. The card that perform client access is a R52, mode is AP-bridge.
Thanks in advance,
.:[CRT]:.
