Hi
I have noticed, from time to time, that a workstation will refuse the DHCP reservation that has been assigned to it
If I allow free DHCP access it works fine i.e. the same workstation properly obtains an IP address
The issue only seems to be linked to reserved IP addresses.
any ideas ?
thanks
yann
dkalam
2
Maybe another station uses the same address (which is staticaly assigned to station)? Happen to me…
Well I discovered a second device, on a different site, that is refusing the reserved IP address
In both cases the routers were RB951G
The first device was a PC, this time it was a VoIP phone
The phone was installed six months ago, and it has worked fine up till now
I haven’t recently updated ROS (currently 6.27)
If I disable the reservation, the phone properly obtains a new IP address
The IP address isn’t already assigned anywhere on the network
very confusing
