reg. user manager auto backup script issue
how to solved this error :-error sending email <may/28/2015 Mikrotik UM Backup by pcare>:invalaid BODY
my mikrotik config backup is coming by email id.. but UM backup is not come. showing above error time to run script.
How can fix the script if you do not show that?
i am share script below…Please check.
:log info “Mikrotik Backup JOB Started . . . By PC CARE TECHNOLOGIES (P) Ltd.”
:global backupfile configbackup
:global mikrotikexport mtexport_backup
:global umbackup um_backup
:global pccaresmtp
:set pccaresmtp [:resolve “mail.pccareonline.in”];
:log info “Deleting old Backup File If available otherwise ignore & process further . . . "
/system backup save name=$backupfile
/export file=$mikrotikexport
/tool user-manager database save name=$umbackup
:log info “Backup process pausing for 10s so it may complete creating backup files”
:delay 10s
:log info “Start Sending Backup File via Email using Pccare SMTP . . .”
/tool e-mail send to=“support@pccareonline.in” password=netabhay subject=([/system clock get date] .
" Mikrotik Config Backup by pccare”) from=support@pccareonline.in file=$backupfile server=192.185.119.103 tls=yes
" Mikrotik Export Backup by pccare") from=support@pccareonline.in file=$mikrotikexport server=192.185.119.103 tls=yes
" Mikrotik User Manager Database Backup by pccare") from=support@pccareonline.in file=$umbackup server=192.185.119.103 tls=yes
:delay 40s
:log info “Backup Finished”
:log info “Deleting Backup File. All Done.”
/file remove $backupfile
/file remove $mikrotikexport
/file remove $umbackup
