Hi All,
We are trying to establish an point to point wireless link using Mikrotik routeros
Router os version 3.0
Configuration
Unit 1
Ethernet1 ip : 192.168.1.2
Wlan1 ip : 192.168.2.2
Eoip tunnel 1 : remote ip : 192.168.2.3
Tunnel id : 5
Bridge1
Ports added : eoip tunnel and ethernet1
Unit 2
Ethernet1 ip : 192.168.1.3
Wlan1 ip : 192.168.2.3
Eoip tunnel 1 : remote ip : 192.168.2.2
Tunnel id : 5
Bridge1
The link is up with -50 rssi and is visible in registration tables on both radio, but the Ethernet interface is not bridging.
We are not able to ping the remote Ethernet ip on either side
These were the same configuration we used on order version 2.9.5 running 133 and others boards and it always worked
One thing we also noted was that in the bridge1/port the role for eoip tunnel and ehtenet1 is defined as designated port but earlier (2.9.5) it used to be in forwarding mode
Any help?
