Go out with a shotgun and find the owner of that “Shenzhen Vsun Communication Technology” device?
Other than that, there is not much you can do. You are on wireless, anyone can try to break into your network. Fact of life.
Well, you can probably improve the configuration of your network a bit, e.g. setup SNTP client so you have correct date/time, but that is not relevant to this problem.
