Hello, i was Monitoring my Mk 532A with xr2 cards, and i saw the noise floor was -85dbm, and the other interface is -101dbm, how good is that?
thanks
thanks
-85 is bad 101 is good
Just had to add, -85 is really bad. Lots of noise.
I get -85 noise on an SR9 signal that hasn’t locked in yet. Often, after its locked in, its better that -77dB. If you get a -85 on 2.4GHz, someone is cranking some decent power on that channel.
