Regarding Powerfull Wireless Link
Dear All,
I need to create a Point to Point Wireless Link with 200Mbps + Bandwidth Capacity and its range is 8-10 Km so which product i must use as i have tired on Netmetal with 30 DBi Solid disk and it is connected to -30/-30 but it is not capable to transfer bandwidth more then 60 Mbps so kindly suggest any setting required or need to install any other product. I belong to India.
Have you done an spectral scan? You’ll need a non AC Mikrotik radio (or other brand) to carry it out.
Specific scenario 5GHz Spectrum is what will dictate what speeds can be achieved, regardless of equipment used.
If there’s 40MHz contiguous spectrum available, you may get near those 200Mbps. If there isn’t, no matter which equipment you use, you won’t reach such speeds… laws of physics.
Pukitta is right. Signal is not the full story, you need to check for interference, noise, and if the full 40MHz is free, not just the center frequency. Experiment with different frequencies, and move your center channel around (eeeC, Ceee).
can anyone tell me how to post snapshot of my device configuration because i want to show you the configuration…
