Regarding RB112
Hello
i have Routerboard 112, but i have a problem the Ethernet port shutdown constantly but sometimes works great. i upgrade the unit version 2.9.5 but still doing the same, how could fix this issue?
thanks.
Your ethernet could ether be a software failure or a hardware failure… You have to debug which it is, connect via wireless, screw with your ethernet see if it is sending packets and bytes ping it etc etc.. If it is hardware go get a rb133c or something.. These routerboards are getting pretty old.. good luck -Jordan
