Register but dont make ping
I have a link of 11 kilometers and i can get a signal strength of -70 dBm, the interface are running and i can configurate with winbox a client radio from ap.
But i cant make a ping from ap or from client.
The link configuration is:
both cards tx power 26dBm
frequency 5820
nstreme with best fit
client antenna grid 29 dBi
ap antenna grid 26 dBi
Sorry i can fix the problem, was the hardware bad attachment
:unamused:
Some more config information could help a lot:
  • How are your wireless interfaces set up?
  • How are ip addresses configured? Routes?
  • Firewall rules?
Best regards,
Christian Meis
My cards are atheros 5212 SR5
I dont have routes and firewall rules yet only have a bridge
but i dont see ack on the link
And my noise floor is -110
my link is over the sea i think, that sea affect.
Note i can passtrougth with winbox utility but i dont have make a ping
you have to setup ip address in both AP’s Wlan interface the make ping or just do the following
make brige LAN and WLAN
in both router
then your hole link will be acking like cable
