reinstall routeros. will loose license ?
hi
i need to reinstall routeros on a x86 PC. if i check that i do not want the configuration will i loose the license key ?
if u use same HDD u will not
but why reinstall?
thx for info.
i have made a really stupid mistake. i have added a “system reboot” at the end of a script with is executed just after startup :stuck_out_tongue:
