Reinstall via Burn ISO CD
Hi there,
I need information how to reinstall mikrotik via burn ISO without loosing my soft-id. The storage is still the same device, my question is :
  1. when its come to format the storage question, will it change my soft-id if i answer yes ?
  2. i will reconfigure the box all over from beginning, will it change my soft-id if i answer no when it ask me to keep old configuration?
Please not point me using netinstall.
Any help will be appreciated, thanks
Simple question, but no one interest to answer it. Thanks
you wont lose your soft-id with the cd install. on 2.9.51 im curious if you get a memory leak after 3-4 days however, if so report back please.
similar questions being asked many times, that maybe why :stuck_out_tongue:
  1. Installing ROS via CD.ISO will not cause to loose SOFT-ID, unless you do low level format on the Disk (CF or HDD)
  2. Reconfigure the box all over from beginning, will not change the soft-id
    even it is asking to keep old configuration when answered as no.
    This will only reset the configuration to 0 setting, similar to ‘/system reset’ command on RBs (or console) while it is retaining the original SOFT-ID.
    Backup files are and will still remain in the disk even it is resetted, unless it is erased manually.
Hope this help.
it’s weekend, that’s why no activity in forum
Thanks all for the answer. Now i can do it without worries.. ^^
