I’m using my rb133 and then it just goes kaput - cant access via winbox or other interface.
I get a null modem cable and here’s what i see:
RouterBOOT booter 2.11
RouterBoard 133
CPU frequency: 175 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
Starting services…
Shutting down…
Stopping services…
Demo license expired!System halted.
Please reinstall the router.
How exactly do i go about reinstalling routeros? I have a 2.9 with level4 license. I’ve installed netinstall but i cant get to acess the rb133.
I’ve gone thru d manual a dozen+ times.
Problem is the rb133 shows up in hyperterminal (via console) but when i press any key to enter setup (within 2 seconds!), it doesn’t take me into the bios, it just goes ahead and loads kernel from nand… and then tells me its starting, then shutting down, then to reinstall the router.
I did get the bios. I reinstalled the software to the latest version. Now it says I dont have a software key. It will stop functioning in 24hrs. They RB133C comes with a license.
