Hi!
We are running mikrotik rb112’s on clients side and 532’s on ap’s. If I transfer a file via skype from 1 user to another user on the network skype tells me the following
What is a relayed transfer?
A relayed transfer means that you are unable to make a direct connection to the other party because of your firewall or NAT (Network Address Translation / router) configuration or that of the remote party. In this case, the file transfer is relayed though other peers on the network. When a transfer is relayed, Skype will limit the file transfer speed to 1.0 kB/second. Only peers with plenty of available bandwidth are used for relay purposes.
Note that if you were using another non-p2p application to attempt the transfer, it’s not likely you would be able to transfer anything at all! We feel that a slower transfer is better than no transfer! You can read more information below for technical tips on how to avoid relayed transfers (or find a techie friend to help you).
Even if I connect 2 users via hamachi, its also relayed.
This only happens with people on this wireless network. If I connect via my adsl at home, and transfer to someone on the wireless network it works perfectly fine. As far as i could gather it has something to do with accepting udp packets on the same network that was send out.
Anyone got ideas that i can try?
Thanks!
Chris
