Release 4.14
What’s new in 4.14 (2010-Dec-10 12:07):
*) radius - fixed Disconnect and CoA response signature generation;
*) radius - do not include NAS-Identifier & NAS-IP-Address in
Disconnect and CoA responses;
*) added hotspot html variable “host-ip”;
*) wireless nv2 - fixed station-wds mode multicast problem;
*) wireless nv2 - fixed occasional encrypted link stalls;
Please note that the wireless-NV2-4.14 package is missing from the “all_packages” folders.
So you must install “routeros” combined package to get it before installing
additional packages or you could loose connection to your NV2 site.
RGDS
Attention: RB1000 bootloader upgrade is broken in this release, for RB1000, do not use the “/system routerboard upgrade” command
voltage is right now thanks team
Thanks for the report
I installed the routerboard update.
I would like to get my old configuration back.
Now how can I undo the update?
the bug reverses the routerboard reset jumper function, so that when it’s not shorted, it resets the configuration upon reboot. we will release v4.15 within the hour, it will stop resetting after you upgrade. check in the Files directory if you don’t have any recent backups or supout.rif files.
Can you be more specific? Does this affect only RB1000 or all devices? Great quality control Mikrotik!
RB1000 only.
