release date of ros 5.0rc6
just wondering if they were getting close on it. Can’t wait to try nv2 again in ptmp environment. thanks
There are currently 19 changes in the RC6 Changelog, and we are working on a bunch more. To compensate for the quick v4 release :wink:
I hope it will be out this week, and I think you will like it.
cool and thank you
Good response Normis !!
Simple and to the point.
Also, these RC releases just keep getting better..THANKS !!
“This week” is now last week and notting happened :slight_smile:
we added even more ipv6 support. let’s hope for a Christmas miracle :slight_smile:
Normis:
I like how your avatar has evolved. Its almost like it has evolved with each RC.
We’re just sitting beneath this big green tree mouth wide open :astonished:
This will be a long week. :slight_smile:
released
Let the party begins… :mrgreen:
Yes :slight_smile:
What’s new in 5.0rc6 (2010-Dec-23 13:33):
*) ntp server now requires a broadcast address for broadcast mode to work
it should be specified under broadcast-addresses (X.X.X.255),
255.255.255.255 is not going to work;
*) ssh - fixed showing forwarding settings,
check your setting after upgrade!
*) allow to specify multiple networks (including IPv6)
in user’s allowed-from list;
*) added support for Safe Mode to WinBox;
*) allow to specify non acceptable groups for RADIUS console logins;
*) handle correctly IPv6 address on bridged or switched interfaces;
*) added IPv6 connection list;
*) added IPV6 support to graphing;
*) added IPv6 support to SNTP client;
*) added IPv6 support to NTP client & server;
*) added IPv6 support to RADIUS client;
*) added IPv6 support to snmp;
*) added IPv6 support to tftp server, also changed logging levels;
*) added IPv6 support to ssh client;
*) added IPv6 support to watchdog;
*) added IPv6 support for /tool e-mail;
*) added IPv6 support to log remote target;
*) added IPv6 support to API;
*) added IPv6 support to winbox;
*) added IPv6 support to ftpd;
*) added IPv6 support to netwatch;
*) added IPv6 support for /queue simple;
*) added IPv6 support for /tool bandwidth-test;
*) added IPv6 support for /tool torch;
*) added IPv6 support for /interface vrrp (version 3);
*) added IP/IPv6 over ipv6 tunnel interface (/interface ipipv6);
*) added Ethernet over IPv6 tunnel interface (/interface eoipv6);
*) snmp - added ipv6AddrTable from IPV6-MIB;
*) wireless nv2 - fixed station-wds mode multicast problem;
*) wireless nv2 - fixed occasional encrypted link stalls;
Please, use this topic for 5.0rc6 reports, comments and experience,
http://forum.mikrotik.com/t/v5rc6-released/43288/1
