I use the enhanced failover script from the WiKi which works fine in itself. But the used IP is from Google and that´s not so reliable as I would expect. I run pingmonitor on it and see it not returning pings at times.
I tried to use my ISP dns addresses but they go down at times as well.
I even tried somebody else’s ISP address but even so, failures at times.
When there is a failing sequence of 5 pings my networks routes out to another WAN gateway but that’s only because the specific server in the script doesn´t return the ping. I can still browse or ping other nodes on the WAN, even through the gateway that is supposed to be down. (it´s route is just down, a PC on the WAN side of the routed but on the LAN side of the ADSL modem can still function normal, apart from the failing ping to that specifice node.)
Does anybody has a very reliable ip that is virtually always up?
Or who can write me a script that for instance checks two nodes before the route cost in the ip/route/default route cost is changed? I´m a no-know in scripting so could use some help here…
