I have a working hotspot setup with some banner advertisements in the login page that I change out pretty often. I have been trying to figure out how I can remotely view the mikrotik’s web server. So, for instance, when I make a change to login.html remotely, how can i view what the Mikrotik is serving out to internal hotspot users?
I tried to forward a port to the mikrotik’s internal IP address but this did not work for me… Any Ideas? Is Anybody currently doing this?
Thanks in advance
You can setup an eoip tunnel and put it in a bridge with hotspot to be on the hotspot side to see the login page.
Example:
SiteA - mikrotik with public ip
SiteB - mikrotik with public ip and hotspot running
eoip tunnel from SiteA to SiteB
SiteB - bridge with eoip interface and hotspot interface
Job done.
Thanks for this idea. That sounds like it would work. Do you know of anyway to do this without another mikrotik device?
For instance how can i do this from the airport?
