Remote Access: Urgent please help!
Hey,
I am currently in a halls of residence where I have setup the RouterOS. How do I gain access to the router remotely?!?!? I am really struggling. Which ports do I use for WinBox. The RouterOS is sat behind a Cisco ADSL 1800. Just need the port forwarding info etc.
MANY MANY THANKS!
winbox tcp/ip port 8291
The error I am getting: could not fetch index from xxx.xxx.xxx.xxx (port 80) Not Found
what is your winbox version, check if that is newest one, if that does not help, then provide it with port 80 also…
strange
i have same problem…
i had done port forward 8291 TCP port from my router (fritz) to internal IP (192.168.1.100).
When im trying to run WINBOX from my work using Connect To:example.no-ip.org:8291 , i get error msg “Could not connect to xxxxx (port 8291) - no response!”
winbox loader is version 2.2.10
