Hi!
I have a problem accessing a mikrotik remotely via Winbox.
When I try to connect, the process freezes on the login part, as shown in the image1 in attachment.
The RouterOS and firmware is updated (version 6.45.9).
I checked if it could be a problem related to the ISP, but a test done through PowerShell shows that I can establish a connection with the remote IP and the port on which the service is hosted (image2).
I can only access winbox through a computer on the mikrotik local network.
I’ve tried to connect through different devices and on different external networks and the behavior is the same (freeze on the login part).
The firewall filters were all disabled to check if he was responsible, but it made no difference.
I’ve read other topics with the reported problem, and checked the suggested possibilities, such as:
- No default routed configured.
- Outdated Firmware
-Reboot router
But none of the options had any effect
Any ideas?
Thanks a lot!
