Remote CAP Address inconsistent
Hi all,
This isn’t really a problem as I have 40 some APs working perfectly with CAPsMAN now just upgraded to v6.36.
However I was wondering why some APs will identify with their IP address and some just have the MAC address.
Many of the units were configured identically and I don’t see any configuration differences.
Is this a bug or standard operating procedure?
i have the same problem any solution to this ?
thank you in advance
No real change however may I ask if you are running Hotspot on this network?
No i am not
What hotspot is used for ?
by default the MAC address option is chosen but if the CAPsMAN was not accessible via MAC it switches to IP.
If you want you can force to use just the MAC or just the IP.
Thanks Uldis!
I looked closer into the documentation
However I’m not seeing where I can specify one method over another. Could you please show me where on either the CAPsMAN or the AP to configure?
Very appreciated!
me too can’t where to do it
How can I force just the IP ?
JF
Can anyone shed some light to this issue? I am experiencing the same behavior on “latest” v6.48.6 (long-term).
Did OP ever get an answer?
Some of my RBcAPGi-5acD2nD are shown by IP, others are shown by mac address. most irritating to me :slight_smile:
The CAPS which are listed by IP are on different switches than those listed by mac address. Could this be a factor?
Hello, I had the same problem - solution is disable discovering in CAP settings - use request certificate and lock to capsman. It works!
