remote connect with the dude
hi there everyone,
please help me on this issue:
i have installed the dude on two computers - one is the server and with the other i want to remotlly login into the server.
i’ve opened ports for both of them but cannot connect, am i doing something wrong?
one computer is defind as server and with the other im trying to connect with mode “remote”.
when im trying to connect im getting an error:
“connection failed: no connection could be made because the target machine actively refused it”
please advise!
thnx!
I have run into this problem on several occations. Some of the reasons i have found is that either you are not allowing connections from the network that your are trying to connect from. On my system i have a firewall that will lockout any unknown ip address’s if i have not allowed them through the firewall. You should ping the system you have the dude server on from the one you are trying to remote with. If it does not reply back that is your problem. You must have access to the network in which you have the server on.
