I’m using PPTP server in 450G router board clients will be logging in through different ISPs from different location, i want to login to the client system through remote desktop. How can i do this.
Sri
Sri
Once the client establishes the PPTP connection simply connect to their PPTP client IP address using the remote desktop client.
I’m not sure I understand the question.
So you want to be able to connect to client computers that connect to your router via PPTP? As long as the pool of addresses that you assign to clients connecting to a PPTP tunnel is not part of any local subnet on the router, the router should handle the routing to them when you try and access the “local” IP address of the computer provided you are using the 450 as your default gateway.
