Remote Device Management
I wanna setup a Remote Device Management for several MikroTik’s. For that I have a default configuration with give me basic connectivity to my remote device management. I setup a trigger on the PPPoE Session to poll (via HTTP) my Remote Device Management (with is a web and application server).
The Remote Device Management should configure now the additional services based on parameters given by a RADIUS Server based on the Request IP Address. This step is a littebit tricky.
  • How can I setup a config that load at any restart?
  • What is the best way to configure the MikroTik (API, SSH) with CPE individual parameters?
Best regards
Hary00
Have you looked at Mikrotik theDUDE Application?
http://www.mikrotik.com/thedude
in my opinion TheDude is won’t fit my requirements. Is it possible to show as CLI commands a current configuration of the MikroTik? I would take that as template and fill a few parameter user-based. I think that’s how Cisco does it.
greetings
