Hi guys!
I know this was a subject to many discussions here but something is not right in my config:
- Cisco/Linksys E2500 as a gateway - static 192.168.1.254, with DHCP server;
- RB435G as a main device for local network with following config:
- wlan1 (WAN) - connects to E2500 and dynamically gets 192.168.1.100 (as assigned);
- wlan2 (LAN) - acts as an access point for local clients; static 192.168.0.254; DHCP server: gateway-192.168.1.254; DNS-192.168.0.254, 192.168.1.254, 8.8.8.8; pool-192.168.0.1-192.168.0.253;
- ppp-out1 (WAN2) - Some Huawei dongle: Add Default Route enabled. I’d like to use it as a failover.
Nothing fancy. The ppp-out1 is usually down and everything works fine while I use wlan1 as WAN. After enabling ppp-out1 and disabling wlan1, proper (I hope) dynamic routes for ppp-out1 are being added but the Internet connection on 192.168.0.0 hosts is not working.
I’ve tried adding masq for ppp-out1 to no avail but I can see packets/bytes counter ticking.
There might be a problem since my 3G provider displays a webpage to enter the captcha prior to granting access to the Internet - this page won’t come up.
I know that failover would require some scripting as simply rising route distance of ppp-out1 might be not enough but first of all I need to get the simpler config to work.
Any thoughts on that? If you need some code, jlmk.
