Hello!
I have a problem with remote logging.
I have a core router (rb1200) and some rb750. All of the rb750s are connected to the core router. I have a syslog server connected to the core router(cr). From th CR remote logging works perfectly. But when i try to set it up on the 750s on the same way it doesn’t work. What can be the problem. The i have to set up some firewall rule? I can ping the syslog server from every router.
Thanks for the help!
Daniel
You need to make sure that UDP Port 514 is allowed through to the syslog server.
Nick.
Is there a way to check it?
