Remote LTE CPE Management?
Are there any existing tools that facilitate remote CPE management when the CPE is off your network? For example, Cambium has their cnMaestro tool that devices will remotely connect to and log data there.
I’m in the process of finishing my L2 management tunnel configuration for the purpose of remote CPE access and SNMP data logging. I figured I should ask if there is already something that exists or is built in before I deploy my method.
Thank you, Chris
