Goodmorning everyone. I am looking for a solution that I cannot find. Maybe some of you can give me some good advice.
The problem is simple. I have implemented a hotspot but I don’t want to give users the possibility to log in on their own. I would like that from my workstation to be able to enable a user to browse, as if I were in his place. In practice I should force a user, connected to the RouterBoard, to be active.
Is it possible using the API or some other functionality?
