Remote management of wds ap
I have come across a strange occurnece and not sure what is the casue. I WDS to RB411u boards toghther. Board A plugs directly into router for internet Board B is the stand alone unit.
Everything works fine except if I do not have anything plugged into the LAN port of Board B I can no longer communicate with it. Clients can still connect up to and surf from it but I can no longer remote mange into it. As soon as I plug back into the lan por I can then remote mange back into the AP.
In my setup I have the lan, wan and wds ports all bridged togther, and the bridge port has the IP address. I have treid remove the lan from the bridge disabling the lan and also just asign an IP to the wan port of which none of this works.
In the end I want to be able to remote mange Borad B while it is in wds mode and nothing plugged into the lan port of it.
This is how I do to get access to board B when running WDS by using Winbox.
If you are running a hotspot in board A, bypass the MAC address of board B under IP > Hotspot > IP binding.
Then click Tool > Telnet.
You can telnet to board B by using MAC address or IP with CLI command.
Hope this help.
PS: If anyone knows how to get access to board B by using winbox, would be great. I used to make winbox works with board B when running WDS by using SSH with tunneling but for some reason, the lastest version doesn’t work. ><"
I think I have a little different problem I can winbox into the unit b as long as I have something plugged into the lan port of unit b to make it active, I can winbox into it remotly. As soon as the lan port becomes inactive I can no longer winbox remotly into unit b.
Post the output of “/ip address print”, “/ip route print” and “/interface print” first with something plugged into the LAN port, and then again with the LAN port empty.
Below is the output
Thanks,
Lan Cable pluged in
[admin@MikroTik] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.10.15/24 192.168.10.0 192.168.10.255 bridge1
[admin@MikroTik] > ip route print
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE IN..
0 A S 0.0.0.0/0 r 192.168.10.1 1 br..
1 ADC 192.168.10.0/24 192.168.10.15 0 br..
[admin@MikroTik] > interface print
NAME TYPE MTU L2MTU
0 R ether1 ether 1500 1526
1 R wlan1 wlan 1500 2304
2 R bridge1 bridge 1500 1526
3 R wds1 wds 1500 2304
Lan Cable unpluged
NAME TYPE MTU L2MTU
0 ether1 ether 1500 1526
2 R bridge1 bridge 1500 2304
As far as I know that shouldn’t be, particularly once you remove ether1 as a port from bridge1. In both cases the IP address is showing valid, and the router to the directly connected network is active.
I may be missing something here, but I’d write to support.
