I have installed and configured an RB532 and I would like to access remotly via winbox or ssh to manage my router.
I follow the guide to secure the router on wiki and I couldn’t access. Could you help me please.
try connecting from local interface, or try serial console
I can connect locally without any problem. But i would like to have an remote access. When i have to modify one parameter, i would to do it from my office.
you have to add entry to firewall chain=input to accept traffic from remote address.
‘ip firewall filter add chain=input src-address=remote_address action=accept’, place this rule before the ‘drop’ rule.
Thanks, i will try.
Regards
I always can’t access to the router. Where can i find good tutorials that describe the procedure ?
If you are asking tutorials about firewall,
http://www.mikrotik.com/testdocs/ros/2.9/ip/filter.php
http://wiki.mikrotik.com/wiki/Firewall
guides provide information about configuration.
Basic TCP/IP is very recommended for the firewall configuration.
Hello Friend,
I think, when your networks consepts as transparant network you are without problem will connect to other, or check your firewalll policy...
here, we can connect until next....next ....and next routers..
