Remote monitoring of Starband CPE
I have a small network using Starband / NOVA as backhaul. Using a RB750UP downstream of the CPE to manage things.
The Starband CPE has the ability to display certain system parameters (signal level, status) via a web-based utility accessed via 192.168.1.1.
I would like to be able to view that stuff when away from the site. Is there any way to set up a firewall / NAT / whatever rule on the 750 to “loop back” to that address when I log in via the SB gateway? I haven’t figured out any way to get the web based utility moved to another port, which means it’s listening on port 80, which complicates things.
