Remote printer via l2tp
Environment:
Mac / PC (192.168.1.10) → Synolgoy router → Internet → Mikrotik (LtAP LTE) → Printer (192.168.88.20) connected via Ethernet
Goal:
To print from Mac / PC on the outside office printer.
Current config:
Mikrotik as a l2tp client connect to Synology router - Done
Ping from MT → Synology OK
I have the current config …
# aug/20/2022 10:31:38 by RouterOS 6.48.6
# software id = 0VN5-9AFF
# model = RB912R-2nD
# serial number = ************
/interface lte
set [ find ] name=lte1
add admin-mac=************* arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=outdoor mode=\
    ap-bridge ssid=MikroTik-A3918C wireless-protocol=802.11
/interface l2tp-client
add allow=mschap2 connect-to=************ disabled=no ipsec-secret=\
    ********** name=l2tp-out1 password=********* use-ipsec=yes user=vpn
add comment=defconf name=WAN
add comment=defconf name=LAN
add add-arp=yes address-pool=default-dhcp always-broadcast=yes disabled=no \
    interface=bridge name=defconf
add comment=defconf interface=lte1 list=WAN
    192.168.88.0
/ip dhcp-client
add default-route-distance=100 interface=bridge use-peer-ntp=no
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1,9.9.9.9
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=VPNonline \
    passthrough=yes src-address=192.168.88.2-192.168.88.254
add action=masquerade chain=srcnat out-interface=l2tp-out1
add action=dst-nat chain=dstnat disabled=yes dst-address=31.61.225.149 \
    dst-port=1024 in-interface=l2tp-out1 log=yes protocol=tcp to-addresses=\
    192.168.88.108 to-ports=1024
add distance=1 gateway=l2tp-out1 routing-mark=VPNonline
/system clock
set time-zone-name=Europe/Warsaw
/system gps
set port=serial0 set-system-time=yes
/tool mac-server
/tool mac-server mac-winbox
Any help appreciated.
oki-doki this could be a couple of things, first thing ill get you to do boss is log into the mikrotik and see if the mangle rule is actually counting up when trying to get to the other side, if this works I would also make sure that your masquerade is working as well.
one thing to note about your mangle is that it will be inspecting every packet and marking the routing for it, you can reduce the cpu load be making 2 mangle rules, the first rule will be the one where you filter the traffic down to just want you want then the action will be mark connection and make sure passthrough is ticket. Under that rule you would then make a new one but this time just filter for the connection mark you just made then have the action as mark routing.
Another thing that is extremely important is packet flow; https://wiki.mikrotik.com/wiki/Manual:Packet_Flow
take a look over that link and try and come up with an idea on what the mark connection and the mark routing chains need to be then post your response here so we can confirm if its right :slight_smile:
last thing I would like to mention is probably why this is not working, and its a guess without knowing what’s configured on the sinology BUT I can see a nat on your VPN interface :stuck_out_tongue:
This implies that there might not be a route for the 192.168.88.0 network on the sinology side?
If this is the case the behaviour would be:
Pinging from pc to printer:
pc sends its traffic to the sinology as the destination address is not on its subnet and its the main router, the sinology then looks up in its rroute table and has no spesific route for this address so it chucks it out the 0.0.0.0/default route and it will then get dropped by your isp cos no one wants private traffic on the net.
Pinging the PC form the printer:
The printer sends its packet to the mikrotik, the mikrotik looks up the route and it has one this time going through its VPN interface but before it does your masqerade rule for the vpn will translate its source address to the vpn clients IP address and then goes on its merry way to the pc.
This gets routed through the vpn to the synology, the synology knows where the pc is since it has a connected route installed and the packet makes it there.
Now for on the way back we have to remember we changed the src-address to the vpns, highly important.
So the pc sends it packet to the synology since its the gateway and then from there the synology looks up the route for this traffic, since the traffic got translated to the IP address on the Mikrotik side of the sstp tunnel the synology knows to put this traffic back over the vpn where on the other side it will be translated back to the printers ip and the return packet sent to the printer.
This is a great method if you need just need to initiate a connection from one side(in this case the printers) to fix this you can just remove the nat for the vpn interface as it will no longer be needed then all you need to do is log on to the synology and add a route for the printer going through the vpn interface :slight_smile:
