do any of you guys do reboots on remote MT devices? i’m starting to think i took this for granted. but now out of only 10-13 remote reboots over teh past year, i’ve had 3 times when the device never came back up and required a power cycle…two times this happened on 2.9.24 and now one on 2.9.30
Luckly the MT stuff is SO solid i NEVER have to reboot (i have APs with 100s of days of uptime and never any issues..these all serve laptop wifi ppl), but when i do, do a reboot i expect the device to come back, or is this common knowlage that you dont do remote reboots unless you MUST and i missed the memo?
don’t have problems with RBs doing remote reboot. I did once, but that was because someone left a serial cable plugged into the console.
PCs once in a while will have a setup issue or bad bios/battery and not reboot properly. No fault of routerOS. “Keyboard error - press F1 to continue.”
well luckly about 1 1/2 min before i did this reboot which never came back, i did a supout for a different issue, so i emailed it to support to see if they can see what happened…not that i think its anything specific, but this rb has done this before.
yea i had/have watchdog on…well luckly (or not ) the location has iffy power and looses it about once a month now for the past year…last time was sept 18…so lets keep our fingers crossed i have UPS on everything EXCEPT this device so that good…everything else runs off PoE switches so i can always do very easy remote reboots..
with my luck ill be waiting months for a power outage..
tks
edit: oh and i have yet to have any flash related issues either.
We’ve had this happen on wrap.2c boards. Upon a power cycle, they can get a errors on disk, requiring the disk repair - this is when they fail to reboot. Some flash cards do this more than others (Lexar, PQI, PNY have all lost our trust). Never seen this problem on Soekris or Routerboard.
that’s because routeros doesnt load the cpu specific kernel modules, to support the cpu specific reset instructions, before issuing the reboot. to make wrap work in this manner you need to add additional software interrupts to the wrap bios (or tamper with the loading sequences, but i do not recommend that) to get it to work right.
the disk error can be something as simple as buffer on the CF was not completely written to do disk before the power was gone (this is not a big issue for the integrity but must be handled before mouting a journaling filesystem to not overwrite the pending journal entries). almost all CF cards default to DMA mode transfers and wrap 2c does not support DMA which can easily trigger relativly harmless errors like that.
