Remote reset of RB500
I am considering deploying RB500 with an 802.11a mini-PCI card as an access point. Many access point manufacturers allow remote hard reset of their devices using one of the PoE wires which resets the device when grounded. Is any feature like this avaliable on RB500?
I notice the passive PoE base unit supplied with RB500 has a hard reset button. Does this work?
Thanks.
if you have to go to the unit any way to do this why would you just unplug the unit same thing as a hard reset.
if your looking for remote reset then there are a couple of manufactures that you can use for that using the internet or hard phone line.
minute man is one and sentry is the other
Randy
