Remote resets - run-after-reset doesn't work? (ROS 5.0)
I’ve been trying out ROS 5.0 on a couple of local CPE’s and we have found that sometimes after many upgrades the boards can act odd (2.9.51 to 3.0 to 3.30 to 4.10 to 4.16 to 5.0) So i’m looking for a way to remotely reset the CPE and bring up wireless. I’ve loaded a simple RSC
/interface wireless set wlan1 ssid=MYSSID channel-width=20mhz band=5ghz-a/n scan-list=5180-5380 mode=station-wds wireless-protocol=any hw-protection-mode=rts-cts hw-retries=15 rate-set=configured supported-rates-b=1Mbps supported-rates-a/g=6Mbps,12Mbps,18Mbps,24Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps,12Mbps,18Mbps,24Mbps disabled=no
/interface wireless nstreme set wlan1 disable-csma=no enable-nstreme=yes enable-polling=yes framer-limit=3200 framer-policy=none
and run "system reset-configuration run-after-reset=remote-reset-5ghz-20mhz.rsc " however when the CPE reboots the script doesn’t run, If I run “import remote-reset-5ghz-20mhz.rsc” it works fine with no errors.
Is anyone aware of any problems with run-after-reset that would stop this from working?
