Remote Routerboard NAT causing IP Phone Issues
If this issue has been solved, please point me to the post. I have yet to find an example of how to solve this issue on this forum or using Google searches.
Current Setup:
Site A: Mikrotik Router, Static address, Port forwarding is set up for the necessary ports to the Phone Server. SIP disabled.
Site B: Mikrotik Router with remote IP Phones - Static address, SIP disabled
The Remote IP Phone extensions will work behind a wireless router connected to the Verizon cellular network. They work behind an Apple home router.
Issue: The remote IP phone extensions at Site B will not function properly behind the Mikrotik router with default settings. SIP disabled and the default NAT masquerade entry.
What entries need to be installed on Site B’s router to allow the controls and audio to work properly?
Advice is greatly appreciated.
