Hello everybody
my customer need to change cpe settings remotely such: sid, ip, gw. USING WINBOX. when i do remote scan? is possibile to made changes and commit? like airOS ?![]()
Best regards
Giuseppe
Hello everybody
Best regards
Giuseppe
To change the configuration you can do it like this:
Regards,
Nikola
edit HOW?
but remote scan?
sorry didn’t noticed that the backup file is not editable. I was doing it with export file. So for wireless configuration do it like this:
Open terminal and type:
interface wireless
export file=wireless
You will see the wireless configuration file under Files as wireless.rsc
Get the file on your local PC and edit the the configuration
Then from terminal type: import wireless.rsc
You can’t do remote scanning if you access the CPE trough wireless because during the scanning all wireless connections are dropped.
Regards,
Nikola
