Syslog does not work in version 5.6!
Any tips for doing remote logging?
Sandro
Remote syslog works fine in 5.6, but the syntax has changed when compared to previous versions.
Did you set a src-address on the remote action? That’s the most likely cause that it isn’t sending anything.
Post the output of “/ip address print detail”, “/interface print detail”, “/ip route print detail”, and “/system logging export” if you need more help.
