Remote vs Memory Logging Inconsistencies
I’ve noticed some issues with regard to local vs remote logging. I have a syslog server set up (graylog) taking in logs from my devices, the following is the example of output from a CRS112:
10:12:34 system,info router rebooted
10:12:36 interface,info MGMT link up
10:12:40 bridge,info hardware offloading activated on bridge "bridge" ports: ether1
10:12:40 bridge,info hardware offloading activated on bridge "bridge" ports: ether2
10:12:40 bridge,info hardware offloading activated on bridge "bridge" ports: ether3
10:12:41 bridge,info hardware offloading activated on bridge "bridge" ports: ether4
10:12:41 bridge,info hardware offloading activated on bridge "bridge" ports: ether5
10:12:41 bridge,info hardware offloading activated on bridge "bridge" ports: ether6
10:12:41 bridge,info hardware offloading activated on bridge "bridge" ports: ether7
10:12:41 bridge,info hardware offloading activated on bridge "bridge" ports: ether8
10:12:43 interface,info ether1 link up (speed 1G, full duplex)
10:12:43 interface,info ether2 link up (speed 10M, full duplex)
10:12:43 bridge,info "bridge" mac address changed to CC:2D:E0:8D:4F:42
10:12:45 dhcp,info dhcp-client on MGMT got IP address 10.0.30.5
10:13:55 system,info sntp change time Jul/01/2019 10:13:17 => Jul/01/2019 10:13:55
10:14:43 ssh,info publickey accepted for user: admin
10:14:43 system,info,account user admin logged in from 10.0.70.2 via ssh
10:14:48 system,info,account user admin logged in from 10.0.90.6 via web
This obviously all shows up in memory, but I only see logs in graylog starting at 10:13:55, the sntp time change.
Both logging entries are simply
topic=info
, with the only difference being
action=memory
vs
action=remote
Here is my remote action:
 3 * name="remote" target=remote remote=GRAYLOGIP remote-port=PORT src-address=0.0.0.0 bsd-syslog=yes syslog-time-format=bsd-syslog syslog-facility=daemon syslog-severity=auto
UDP is used to send messages to syslog, and there is no buffering. So the sntp-related event is the first one which could be actually delivered as all those before happened while networking wasn’t up yet.
This makes sense.
Is there no way to buffer logs to then send once networking is up? What would be the easy workaround for this case?
The same goes for logging to disk … there initial log messages don’t appear as well since external disk (e.g. USB stick) becomes available a few seconds after boot.
What’s the normal procedure for figuring out why a device rebooted or crashed, for example? I noticed the command to send a reboot doesn’t get logged.
