Remote Web access to my Dude server
How do I config the service config to allow remote access from internet
How do I setup settings/Server/“allowed networks”
/Thomas
Hello Thomas!
You can setup:
  1. Startup type - as service: DUDE as windows service without user log on
  2. Server settings - Secure port - port when using encrypted (secure) connection.
    On this port you will connect from your Dude client via Internet. You can leave it default value.
  3. Server settings - Allowed networks - network ranges that can connect to the dude web server interface
    You can allow only this address by specify mask 32(xx.xx.xx.xx/32).[/quote]
    This is External IP from where you will access Dude. You can see it via http://cmyip.com as example.
  4. Admins - Setup username. Default username is admin with empty password.
If your Dude is on Mikrotik device, you can connect to it via mikrotik external IP. If it installed on PC after NAT you should setup port forwarding on your router.
Also, Dude can be accessed via Web Interface.
Thanks for info!
/Thomas
For the latest dude manager, i cannot find where is the web setting, anyone can share ?
dude 6.* doesn’t have web interface
Anyone know how to make dude ping from sub interface ?
