remote winbox
Dear Friends,
below is my topology,
I try to remote winbox to the gateway (connected to the client) using public IP from WAN1-WAN4 (passing load balance) but always fail, but when i do remote to load balance (RB450G) from WAN1-WAN4, its works by using same NAT.
if anyone could help how to route correctly NAT so traffic in and out from same connection, because im using PPC method on load balance.
thanks
Erwin
hello..
i don’t understand about your question, but it’s very easy to remote your RB from outside networks but ip public required.
you have 4 ip public, make 1 ip for redirecting (incoming winbox connection) to your router.
you can also netmap on other ports to your internal routers provided there is one router that can see both sides.
Dst-Nat tcp port 5000 to srver:correct port u want to use
