I would see this remote winbox feature giving us access to MTs with privet IP on the network. You would open winbox and then click on the remote winbox button, it would then give you to IP blanks to enter IPs in. One for the relay MT and the other for the destination MT.
You would then have an easy way of using winbox on a privet range when you anywhere on the net.
Yep, “WinBox-Relay” could come in handy sometimes.
On the other hand there’s always the possibility to use an SSH tunnel for the same effect…
Best regards,
Christian Meis
Yes, the tunnel will work but the “WinBox-Rely” or “WinBox-Remote” would be so much better.
