can I access other computer using port forwarding thru RB750G Mikrotik.
Please help me how to do that.
I’ll do it but didn’t work
I have simply followed the steps and processes posted here and had no problems with it. Not finding any reason for it not to work as that is pretty much standard with anything that you are using on your machine and even on your client’s side. I suggest that you try it again and might as well tinker with the settings on your firewall as that is a likely cause of the problem if you ask me. Hope this helps.
