Recently I install mt 6.40.1. i face a problem. when i remotely access in webfig or winbox. everything comes very slowly but inside the lan everything works well. please help me. where i looking to fix it. Thanks.
#normis please help.
I’m assuming from you lack of details description, that what you describe as “remotely access” your router, that you really mean you are connecting to an internet port as opposed to a local LAN port. The router could not care less which port you are connected to (LAN, internet connection, etc). It will treat any port equally UNLESS you have firewall rules that affect that connection. So please tell us in a little more detail what you are doing if you want our help.
BTW, if what you really meant is that you are remotely accessing a local computer (Remote desktop, VNC, etc) and then accessing WebFig or WinBox from that computer, then I would see if that computer is slow when you operate it locally. If that computer is not slow when operating it locally, then the local computer to the router connection is not the issue. Again, you need to tell us what you are doing in a bit more detail. Also note, that if the router may even be possible part of the problem, then the next step is going to be an export of your configuration so we can see what that looks like.
I have real IP. I access in my router through internet from anywhere. I delete all my firewall rules. Now I have no firewall rules. please tell me, what’s details you needs. Thanks.
Sent from my GT-N7100 using Tapatalk
What is your internet connection?
My ISP give me connection by optical fiber to gigabit ethernet media converter.
