Remotely access Mikrotik router
Hello everyone!
I have a Mikrotik RB951g router in office which we are using internet. sometimes I have to login to the router from home using another connection so I would like to know how to configure the router so I can accessed from home remotely?
This has been discussed many time.
Best option, setup a VPN from Mikrotik to your home. (This will also work of your router is behind nat)
If that can not be done, take care. Open up a router from outside add a huge risc for attack on it.
  • Use access list
  • Do not use default port
  • Use port knocking
  • Log all access
PPTP good too
Brain dead?
The Point-to-Point Tunneling Protocol (PPTP) is an obsolete method for implementing virtual private networks. PPTP has many well known security issues.
I do agree with anav here, why in the world use obsolete PPTP when you can use a much better L2TP with IPsec?
There is a much simpler way… dynamic whitelisting
  1. Get a DynDNS client (or URL) on your client device (hint: could also be another Mikrotik device on the same client network https://wiki.mikrotik.com/wiki/Manual:IP/Cloud )
  2. Add that DynDNS name (not IP address) to Firewall address list in the router you wish to access (hint: timeout recommended but not required https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Address_list )
  3. Add a firewall exception rule for that address list
  4. Result = Secure (with no open ports at all to attack) authenticated encrypted (Winbox / HTTPS) remote access, to as many sites (devices) or users your like with zero overhead
Hint: https://www.cloudns.net/features/ is Google recommended and has non-authenticated dynamic DNS for free ( https://www.cloudns.net/wiki/article/255/ ), including the free domain.
Something along the lines of:
/ip firewall address-list add address=xxxxxxxxxxxx.sn.mynetname.net list=whitelisted-admin comment="some other Mikrotik device with Cloud IP"
/ip firewall address-list add address=mydyndnsclient.dyn.com list=whitelisted-admin comment="some other DynDNS client"
/ip firewall filter add action=accept chain=input comment="Allow whitelisted-admin" in-interface-list=WAN src-address-list=whitelisted-admin
Please note: if the two DNS names resolve to the same IP address then only one item is added on the list.
How does dddn and address list provide secure encrypted connections?
You could also setup IKEv2 and access via the MT mobile App from anywhere, home, coffee shop or via cellular data.
Mikrotik’s implementation of PPTP is secure. It’s the Windows one you’re mocking my mental disability with.
https://www.youtube.com/watch?v=MMzd40i8TfA
As much as I hate to intervene in this discussion, I must remind to @anav and everyone else to keep it civil and lets not throw insults around.
Ok? Ok!
Thanks for the reminder kris, I have modified my previous post.
