Hi all!
Perhaps you have encountered the problem of remote rebooting the router?
I want to configure a reboot of the router once a week. But it doesn’t have a scheduler (unfortunately i can’t unplug socket physically).
How i can do that?
Unfortunately, this is not possible through SwOS. In case you are using a dual-boot device (any CRS3xx series switch), you could easily set up scheduler in RouterOS.
My solution for this was to set the alarm systems that I have on my remote switches to be able to turn the electrical plugs on or off. That way I can set routines on the alarm or just do it from my mobile phone, plus, I can monitor current and all other sort of things in the environment, such as A/C temperature.
Perhaps we are read by representatives of Mikrotik. Will there be support for ssh access in SWOS?
I think not. SWOS is very limited, and it needs to be that way otherwise it would become ROUTEROS.
i hope in SWOS v3 get access from SSH and fix all problems!
Yes me too. And hopefully MT release the next version very soon.
