Remove 1 line from firewall rules: spent 2 hours before asking for help
UPDATE: OK. This is silly. I was able to print the entire list with number for rules with just one command: print
:slight_smile: I was greeted with the entire rules list with numbers. This one turned out to be number 34! Why? No clue. I counted and recounted and it should have been 31. And no 34 came up in the previous print command. &^$&!
So I tried another command: disable
And it greeted me with: number:
So I typed: 34
Bam! Rule gone! But after several attempts I’m now the victim of my own firewall rules. I’m certain I’ve blacklisted the IP I’m remoting in from!
Next step… run a VPN connection and see if I can appear from a different IP address I guess. I’ll post what happens here in case anyone else has this problem. lol Crackin up on myself. :stuck_out_tongue:
I’ve been through the forums for 2 hours now and I give up. I kicked myself out from being able to access a router remotely through winbox with the following firewall rule.
add action=drop chain=input in-interface-list=!LAN
I don’t know what I was thinking. I was on the phone at the time so maybe I just wasn’t.
Now the only way I can get in is through the command line via MAC Telnet through another router upstream on the same network. The router is locked in a comms closet and the site admin is on vacation. I was making some changes for SNMP monitoring for a new system we’re deploying tomorrow and I need winbox access back asap.
I’ve tried dozens of things from various places on the forum but the codes just won’t do what I want. There is no comment in the comment section (The ONLY rule that doesn’t have a comment!) The following doesn’t give me a list:
:foreach rule in=[ /ip firewall filter find action=drop ] do={:put [/ip firewall filter get $rule chain]}
Instead I get
input
input
input
input
input
:put [ /ip firewall filter find action=drop ] it seems should provide a ilst of all rules that have action=drop in them.
What I get is this: *2f;*9;*a;*c;*19;*20;*27;*31
Great, right? It’s the last rule on the list so I figured it was line 31. I can see it via /ip firewall print.
So I tried this: filter unset number=31
The result?
value-name: export
Script Error: action cancelled
So I tried: :put [ /ip firewall filter find in-interface-list=!LAN ] and I get nothing. No errors. just the next prompt.
Browsing on the boards I see something: disable=31 .. and think “Ah. I did it wrong.” (from /IP firewall filter)
no errors.I think I have it. Nope. Print firewall shows it’s still there.
So I give in. Asking for help. I’m sure I’m overlooking something simple but I just can’t respolve this myself and need help. Thanks!
Not right, it could be any of your rules.
You need to find rule by uniqueness. Eks comment, whats inn it etc.
post the output of
export hide-sensitive
mark the rule you like to delete and why, ans we can find a way to do it from a script.
