Remove a connection via script
Using a netwatch script to remove a firewall connection. Using
/ip firewall connection remove [find dst-address=111.222.333.444:5060]
It runs in terminal but the connection never disappears. I need to manually remove it.
Is my syntax wrong?
How do you manually remove the connection?
Just in winbox. Firewall connections tab, select the dst-address I am looking for and hit the remove button.
I think it should be
 /ip firewall connection remove [/ ip firewall connection find dst-address=111.222.333.444:5060]
What’s the reason you’re doing this by the way? I work as a VoIP engineer so maybe I can help.
You may, thanks.
Setup a tik for WAN fail over using netwatch. I want to see wan1 fail, bring up wan2, remove the SIP registration to my voip server allowing it to re-initialize via the new route.
I can manually remove the connection and see it pop back up under the new route but, that defeats the purpose.
Do not use ‘=’ , use instead ‘~’ to match dst-address and use double quotes ..
/ip firewall connection remove [/ ip firewall connection find dst-address~“111.222.333.444:5060”]
Ill give that a shot and post back.
I’m curious, what benefit is this?
Ah ok. It may be better to create a script that clears all connections, unless these lines are used only for SIP.
That line worked!
What I am trying to achieve is keeping a call going even if the primary connection fails. Clearing the SIP registration between the phone and server is my plan. I can clear the SIP registration and it pops back up about 5 seconds later on either connection, which is ideal.
Any insight you can provide into optimizing that would be appreciated.
Glad to hear that
Clearing SIP conntrack item let your sip device start a new registration on the failover link, so that your next call will work. Doing the same on failover you can quick restore your sip reg on regular link.
(I’m assuming a nat scenario) Not so easy and, anyway, sip/rtp conntrack clearing is definitely not enough. You would need some layer2/3 tunnelling techniques and some fast failure detection ability (e.g. BFD)
Someone who has an working script for a failover script that deletes SIP connection back and forward?
