Remove all profiles from user
I would like to remove all profiles from an user using Terminal or API.
At this time, I can use only create-and-activate-profile, but it temporarely disable other profiles and activate the one I’m passing.
When this profile expires, the others are activated.
Is it possible to remove all profiles, before assign a new one?
Thank you
Hi
UM have no command for this problem.
you can save user information in variables and then delete that user and again create that user.
by schedule and a loop.
i think, you can’t do this Except by user manager web management
but you can remove user by api or trminal and create it again and activate new profile
